Fix Your Stuff
Right to Repair
Parts & Tools
Error : Card not Supported
Hi
My Nikon L810 shows the error on the screen as the card is not supported, basically the camera is not identifying the memory card, taught it was a format issue and did try with the new recommended memory card still the same issue...
Please advice
Add a comment
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Answer
Chosen Solution
Have you formatted the card with the camera? Try it a couple times — sometimes these things are finicky.
If that doesn't work, try a different card and do the same thing.
If that doesn't work, share a bit more information about what sequence you're getting the error in.
Update
There was some dust in his card reader — he blew out the card and the reader and it started working again!
Score 1
Comments:
It worked all of a sudden, just used the cam blower to clean the memory card slot and tada!! it worked , thanks Kyle for the advice as you said these things are finicky
by
Hey, awesome! Congrats for fixing it. The 'ole blow-in-the-Nintendo cartridge trick. Awesome!
by
Add a comment
Add your answer
Nikon810 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 213
