Fix Your Stuff
Right to Repair
Store
Introduction
The base plate serves as the under casing for the device. It provide structural security and protection for the internal components. If the base plate is damaged it may put the internal hardware at risk and should be replaced. The rubber covering is held in place by an adhesive and make take some time remove.
Parts
No parts specified.
  1. Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces. This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands. Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
    • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
    • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
    • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Remove the ten 3mm screws with a Phillips #00 screwdriver. The screws with adhesive covering do not need to be removed.
    • Remove the ten 3mm screws with a Phillips #00 screwdriver.
    • The screws with adhesive covering do not need to be removed.
  4. The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate. Pull the base of the wire close to the logic board and the connector will pop off.
    • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
    • Pull the base of the wire close to the logic board and the connector will pop off.
7 other people completed this guide.
Keaton Frahmann
642 Reputation
2 Guides authored
Cal Poly, Team 4-2, Livingston Fall 2016 Member of Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
4 Members
15 Guides authored
2 Comments
I had to open to destroy the hard drive for security reasons. The rubber bottom was so old it just tore to bits. I used a Dremel Multi-Max with a flat scraper blade to remove it in the end.
steve - Reply
must I put back on the rubber bottom or can I leave it off for maximum airflow?
Benjamin Holmstedt - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 55
All Time: 3,955
