Fix Your Stuff
Right to Repair
Store
Introduction
If hot water leaves the automat on the right rear side perhaps the solenoid valve is damaged and must be replaced.
  1. Before you begin: UNPLUG! Remember not to touch current leading parts, if plugged in.
    • Before you begin: UNPLUG! Remember not to touch current leading parts, if plugged in.
  2. Rearside: unscrew two screws, push upside. Side covers: unscrew two screws, push backwards. Top: unscrew four screws, disassemble the adjuster of the grinder as shown in step 3
    • Rearside: unscrew two screws, push upside.
    • Side covers: unscrew two screws, push backwards.
    • Top: unscrew four screws, disassemble the adjuster of the grinder as shown in step 3
  3. Remove the cap, then unscrew the exposed screw. Take away the adjuster. Now you can remove the top of the machine. Now you can remove the top of the machine.
    • Remove the cap, then unscrew the exposed screw. Take away the adjuster.
    • Now you can remove the top of the machine.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  5. Now plug in and try to get a cup of coffee but  CAUTION, don´t touch anything, high voltage. On top of the boiler you can see the valve. Can you see if the water really drips out of the valve? Pull the plug!
    • Now plug in and try to get a cup of coffee but CAUTION, don´t touch anything, high voltage.
    • On top of the boiler you can see the valve. Can you see if the water really drips out of the valve? Pull the plug!
  6. Of course buy a new one at a DeLonghi supplier.  The old one normally has a metal body, the new one plastic. That provokes some problems. You also need raccords for directions in- and out. The outgoing one is double, but there may be differences. In the photo they are already assembled. Attention! The valve has a direction. The sense of the flew is towards the black point. The double raccord must be there!
    • Of course buy a new one at a DeLonghi supplier. The old one normally has a metal body, the new one plastic. That provokes some problems. You also need raccords for directions in- and out. The outgoing one is double, but there may be differences. In the photo they are already assembled.
    • Attention! The valve has a direction. The sense of the flew is towards the black point. The double raccord must be there!
  7. The boiler and valve are fixed with three screws. Also loosen some cables and hoses until the boiler can be removed. The boiler and valve are fixed with three screws. Also loosen some cables and hoses until the boiler can be removed. The boiler and valve are fixed with three screws. Also loosen some cables and hoses until the boiler can be removed.
    • The boiler and valve are fixed with three screws. Also loosen some cables and hoses until the boiler can be removed.
  8. Two screws hold the valve looking upwards. As the old one uses M4 screws you have to cut the thread into the plastic body. Use a threader. and  make a circle  cut into the plastic of the holder of the boiler  in order to let the incoming hose pass by.
    • Two screws hold the valve looking upwards.
    • As the old one uses M4 screws you have to cut the thread into the plastic body. Use a threader.
    • and make a circle cut into the plastic of the holder of the boiler in order to let the incoming hose pass by.
  9. Hopefully you can get a cup of coffee! Then  reassemble all parts.
    • Hopefully you can get a cup of coffee! Then reassemble all parts.
Have a cup of coffee!
3 other people completed this guide.
VauWeh
99,281 Reputation
116 Guides authored
One Comment
Superb,thank you very much !!!
Vedrasco Victor Vasili - Reply
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 169
All Time: 5,771
