Fix Your Stuff
Right to Repair
Store
Parts
No parts specified.
  1. Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
  2. Slide the trigger button retainers slightly away from the front cover. Remove the #1 button on both sides. Remove the #1 button on both sides.
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  4. Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly. Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
  5. Remove the motherboard assembly from the front cover.
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,508
