Fix Your Stuff
Right to Repair
Store
Introduction
Use this repair guide in order to replace the speakers.
  1. Take the battery cover off by releasing the locking tab and hinging the cover away. Take the battery cover off by releasing the locking tab and hinging the cover away. Take the battery cover off by releasing the locking tab and hinging the cover away.
    • Take the battery cover off by releasing the locking tab and hinging the cover away.
  2. Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove the six back panel screws using a Tri-wing Screwdriver.
  3. Remove bottom back panel screw with a Phillips #1 screw driver.
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  5. Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  6. Remove left and right triggers by lifting and pulling them away from the system. Do the same for side panels
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  7. Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  8. Remove the rubber button pads from their pockets. Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand. Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  9. Using the tweezers, gently pull the ribbon from the logic board. Using the tweezers, gently pull the ribbon from the logic board. Using the tweezers, gently pull the ribbon from the logic board.
    • Using the tweezers, gently pull the ribbon from the logic board.
  10. Slightly move the speaker to the right and desolder the two wires from the logic board. Beware of over heating the soldering kit will damage the logic board. Beware of over heating the soldering kit will damage the logic board.
    • Slightly move the speaker to the right and desolder the two wires from the logic board.
    • Beware of over heating the soldering kit will damage the logic board.
Finish Line
9 other people completed this guide.
Adam
709 Reputation
5 Guides authored
Cal Poly, Team 16-29, Maness Winter 2010 Member of Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Members
38 Guides authored
One Comment
When no sound in GBA. Is the broken speaker the most common problem ? Or some SMD part in circuit board ? What to do if the new replaced speaker emits no sound ?
Pekka Hollola - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 143
All Time: 9,145
