Fix Your Stuff
Right to Repair
Store
Introduction
Use this guide to check the health of your battery and whether your iPhone is operating at peak performance. If not, it may be time to replace the battery.
This guide was created on an iPhone X, but can be used on any iPhone 6 or newer, running iOS 11.3 or higher.
  1. In order to proceed with this guide, your device must be running iOS 11.3 or higher.
    • In order to proceed with this guide, your device must be running iOS 11.3 or higher.
    • Open the Settings app.
  2. Scroll down and select Battery.
    • Scroll down and select Battery.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  4. Select Battery Health.
    • Select Battery Health.
  5. Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new.
    • Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new.
    • Over many charge and discharge cycles, this number will gradually drop.
    • Your iPhone should continue to work fine, albeit with shortened battery life. Apple typically recommends replacing the battery once it degrades to 80% or lower.
  6. Peak Performance Capability tells you whether your battery can still supply sufficient power for the iPhone's most intense processing tasks. Normal peak performance is what you're aiming for. If it says your iPhone has experienced an expected shutdown, that means your battery couldn't supply the needed power quickly enough, and the system shut down as a result. Your iPhone will throttle its own performance—slowing itself down—in order to prevent further unexpected shutdowns. This can be disabled to manually enable peak performance.
    • Peak Performance Capability tells you whether your battery can still supply sufficient power for the iPhone's most intense processing tasks. Normal peak performance is what you're aiming for.
    • If it says your iPhone has experienced an expected shutdown, that means your battery couldn't supply the needed power quickly enough, and the system shut down as a result.
    • Your iPhone will throttle its own performance—slowing itself down—in order to prevent further unexpected shutdowns. This can be disabled to manually enable peak performance.
    • Once you disable performance management, you cannot enable it again. It is automatically enabled after an unexpected shutdown.
    • Once your battery falls below a specific threshold (typically 80%), you will be notified that your battery's health is significantly degraded.
    • Follow this guide to replace your iPhone X battery, or click here for other iPhone models.
That's all folks!
18 other people completed this guide.
Josh M
721 Reputation
1 Guide authored
Experimax West Palm Beach Member of Experimax West Palm Beach
Business
5 Members
4 Guides authored
3 Comments
Battery Health no funciona con las baterías iFixit.
Cambié la batería de mi iPhone 6 por una batería iFixit y no se puede ver el porcentaje de batería máximo. Aparece “reparar“.
Con alguna aplicación de análisis de batería muestra 98%.
Jairo Ochoa - Reply
Under “Battery Health,” my iPhone SE says only “Service” and gives none of the information listed here.
Jeremy Nichols - Reply
Most likely your battery is below the recommended threshold and should be replaced.
If you replaced your battery, it may continue to say “Service”. I would recommend using a computer app like coconutBattery to check.
Josh M -
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 97
All Time: 4,018
