Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Performing a force restart should not delete any data, but can be helpful if your iPhone X is frozen, won't turn on, or needs troubleshooting.
  1. Quickly press and release the volume-up button (1).
    • Quickly press and release the volume-up button (1).
    • Quickly press and release the volume-down button (2).
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Finally, press and hold the side button (3) until the Apple logo appears, and then release.
    • Finally, press and hold the side button (3) until the Apple logo appears, and then release.
    • The screen will temporarily go dark as the iPhone shuts down and reboots. Keep holding the button until you see the  logo.
You're done!
83 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
yvaneck
220,835 Reputation
11 Guides authored
iGH Member of iGH
Business
1 Member
67 Guides authored
6 Comments
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - Reply
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - Reply
good share. thanks.
MelissaR - Reply
What is the other way?
sa sas - Reply
will it delete all data from my iPhone?
_TR0xuu_ - Reply
Past 24 Hours: 100
Past 7 Days: 817
Past 30 Days: 3,504
All Time: 223,788
