Fix Your Stuff
Right to Repair
Parts & Tools
Tools
Parts
No parts specified.
  1. Remove three nuts. Use 10 mm wrench
    • Remove three nuts.
    • Use 10 mm wrench
  2. After nuts removed, press gently the screws.
    • After nuts removed, press gently the screws.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Gently remove the light assembly. Gently remove the light assembly.
    • Gently remove the light assembly.
  5. Remove the lamp socket and change the burned-out bulb (12V  5W). Remove the lamp socket and change the burned-out bulb (12V  5W).
    • Remove the lamp socket and change the burned-out bulb (12V 5W).
Jose Gustavo Abreu Murta
2,743 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 129
All Time: 1,198
