Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Removing a few screws will remove this part and allow access to your RAM.
  1. Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Remove the three identical Phillips screws from the memory door.
    • Remove the three identical Phillips screws from the memory door.
  4. Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
6 other people completed this guide.
iRobot
1 Reputation
648 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 6,476
