Fix Your Stuff
Right to Repair
Store
Introduction
If your phone does not charge or hold a charge, it might be time to replace the battery. Replacing the battery is quite simple.
If your battery is swollen, take appropriate precautions.
  1. You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown. This part is moderately difficult, especially if you've never taken the outer back cover off before this point. It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
    • You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown.
    • This part is moderately difficult, especially if you've never taken the outer back cover off before this point.
    • It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
  2. Shut down the phone.
    • Shut down the phone.
    • Push SIM card until it pops out.
    • Remove SIM card.
  3. Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place. Make sure to keep all of the screws together, as they are very easily lost. The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
    • Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place.
    • Make sure to keep all of the screws together, as they are very easily lost.
    • The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  5. Use the plastic opening tool to take out the inner back cover after all the screws have been removed. This will expose the motherboard and the attached battery. Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
    • Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
    • This will expose the motherboard and the attached battery.
    • Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
  6. When you remove the back inner cover, the battery will be exposed on the motherboard. The label is upside down, so do not be alarmed.
    • When you remove the back inner cover, the battery will be exposed on the motherboard. The label is upside down, so do not be alarmed.
    • It is attached by adhesive and connected to the motherboard by an electrical ribbon. So a plastic pry tool will be needed for this task.
  7. The battery is attached to the motherboard via an orange ribbon and a plug.
    • The battery is attached to the motherboard via an orange ribbon and a plug.
    • Use a flat pry tool to unplug the ribbon from the motherboard. Place the tool underneath the right edge and push up. The plug should come free with minimal resistance.
  8. The right edge of the battery will give you the most leverage when removing the battery from the motherboard. Use the pry tool to lift the edge of the battery. Remember: the battery is attached using adhesive. You will meet a lot of resistance in this step. If the battery seems like it is pulling too much at the motherboard, try moving the tool along the edges to work the battery free.
    • The right edge of the battery will give you the most leverage when removing the battery from the motherboard.
    • Use the pry tool to lift the edge of the battery. Remember: the battery is attached using adhesive.
    • You will meet a lot of resistance in this step. If the battery seems like it is pulling too much at the motherboard, try moving the tool along the edges to work the battery free.
    • Try not to rush. It is important that you don't ruin anything in the process of removing the battery. The battery will come free, it will just take some patience and finding the right spot to lift the battery free of the motherboard.
  9. Once the battery is removed, you will be able to replace it by fitting the new battery underneath back camera (the raised silver box on the motherboard) and plugging the ribbon in.
    • Once the battery is removed, you will be able to replace it by fitting the new battery underneath back camera (the raised silver box on the motherboard) and plugging the ribbon in.
    • When putting the new battery in, make sure the blue cover (shown in the top left orange circle) is in place. It is a protector for delicate circuitry, so it is important that the cover is in its place when the battery is put in.
101 other people completed this guide.
Rebecca Montgomery
3,877 Reputation
6 Guides authored
USF Tampa, Team 1-6, Brown Fall 2014 Member of USF Tampa, Team 1-6, Brown Fall 2014
USFT-BROWN-F14S1G6
4 Members
12 Guides authored
30 Comments
Good clear instructions. Thanks.
Motog Steve - Reply
seemed to work for me. fiddly screws though.
Joe Turner - Reply
This shows the second gen moto g but the title is for 3rd gen. Is there a tutorial for the 3rd gen?
wjobrie3 - Reply
This is the 3G version (moto g 2013, the all first version) but not the 3rd version :)
Antoine -
It’s none of those, It’s the original NON-LTE 1st gen, and yes the title says 1st gen
01110011 01101000 01110101 01110100 00100000 01110101 01110000 00100000 01101001 01100100 01101001 01101111 01110100 01110011
Aaron Vey -
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 219
All Time: 96,765
