Fix Your Stuff
Right to Repair
Store
Introduction
This guide shows how to remove a broken internal component for navigation buttons.
  1. Place the camera facing upwards.
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Rotate the orange battery clip in the camera to release the battery.
    • Rotate the orange battery clip in the camera to release the battery.
  3. Locate the eight outer PH 2mm screws on the device. Using the PH00 screwdriver remove all of the screws from the camera. Using the PH00 screwdriver remove all of the screws from the camera.
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  5. Using a plastic opening tool, gently pry off the front and rear plates. Be patient  with this step, do not force the clips holding the plates together. Be patient  with this step, do not force the clips holding the plates together.
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  6. Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  7. Remove the two clasp using a plastic spudger
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  8. You may now remove the internal panel of the buttons
    • You may now remove the internal panel of the buttons
Michael Lynch
396 Reputation
3 Guides authored
USF Tampa, Team 1-2, Remmell Fall 2015 Member of USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 517
