Fix Your Stuff
Right to Repair
Store
Introduction
This guide will show you how to remove the batteries that power the device. If the device won't turn on, try replacing the batteries.
  1. Pull down on the battery cover release lever and pull back to remove the cover. Pull down on the battery cover release lever and pull back to remove the cover.
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Take out each battery then put the covering back on.
    • Take out each battery then put the covering back on.
4 other people completed this guide.
Travis Taylor
319 Reputation
5 Guides authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
23 Guides authored
2 Comments
I don’t know what would I’ve done without this guide thanks.
Carlos Araneda - Reply
The guide is not a joke. Its main task is to be a prerequisite for other instructions.
VauWeh -
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 20
All Time: 5,260
