Fix Your Stuff
Right to Repair
Store
Introduction
This guide will help you remove the front panel of the controller. It is a prerequisite guide only.
Parts
No parts specified.
  1. Pull down on the battery cover release lever and pull back to remove the cover. Pull down on the battery cover release lever and pull back to remove the cover.
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Take out each battery then put the covering back on.
    • Take out each battery then put the covering back on.
  3. Remove the eight 9-mm Tri-Wing screws on the back panel with the Tri-wing Y1 screwdriver. During reassembly, firmly hold the panels of the controller together while replacing screws so the panels don't separate.
    • Remove the eight 9-mm Tri-Wing screws on the back panel with the Tri-wing Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing screws so the panels don't separate.
  4. After each screws has been removed carefully turn over the controller, and place on a flat surface. Slowly separate the top panel from the bottom panel.
    • After each screws has been removed carefully turn over the controller, and place on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off of the motherboard.
    • Once seperarted set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
JT Gryder
63 Reputation
1 Guide authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
23 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,002
