Fix Your Stuff
Right to Repair
Store
Introduction
This guide will show you how to install a new motherboard and keyboard unit in your phone.
Parts
No parts specified.
  1. Flip the phone over so that the screen faces down. Press the gray button on the battery cover and slide it down off the back of the phone.
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Remove the six 6mm T6 Torx screws around the edge of the front of the phone. Remove the metal frame holding the screen and speaker.
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Gently lift motherboard unit out of the case. The motherboard and keyboard are one unit and are replaced together.
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
11 other people completed this guide.
James Szelenyi
232 Reputation
1 Guide authored
Cal Poly, Team 10-43, Amido Spring 2013 Member of Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Members
14 Guides authored
One Comment
you nokia 1100 mother board please soon dateā€¦?
ajay gupta - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 3,588
