Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
This will show hot to disassemble the case for the Jura Z7. this will be necessary for most repairs on this
  1. Unplug the Z7 from the power outlet
    • Unplug the Z7 from the power outlet
    • Remove all attachments like water tank,drip tray, coffee bean cover.
  2. Turn the machine so the back is facing toward the front. The Jura sign must be removed. Turn it a few millimeters in a clockwise direction. If this becomes difficult use a suction cup to assist
    • Turn the machine so the back is facing toward the front.
    • The Jura sign must be removed. Turn it a few millimeters in a clockwise direction.
    • If this becomes difficult use a suction cup to assist
    • Remove the Jura sign
  3. Behind the Jura sign are two screws with an oval head. They have to be removed. These screws have an oval head that makes them look like rivets (picture 2). You need to use a special key or bit for their removal. If necessary, it could be done with a synonymous with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
    • Behind the Jura sign are two screws with an oval head. They have to be removed.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special key or bit for their removal. If necessary, it could be done with a synonymous with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Push the back down a bit and then remove it. Push the back down a bit and then remove it.
    • Push the back down a bit and then remove it.
  6. Pull the right side panel backwards and take it off.
    • Pull the right side panel backwards and take it off.
    • Sometimes it gets a bit stuck and may require a bit more of a pull.
  7. In this step, you should remove the screws of the right side panel. The side panel itself can only be removed after removing the top cover. Remove the Torx T10 screw on the front wall of the side panel. In the side part there is a lid over the brew group. The lid is fastened at the top with two oval head screws. Remove those to remove the lid.
    • In this step, you should remove the screws of the right side panel. The side panel itself can only be removed after removing the top cover.
    • Remove the Torx T10 screw on the front wall of the side panel.
    • In the side part there is a lid over the brew group. The lid is fastened at the top with two oval head screws. Remove those to remove the lid.
    • With the cover removed the brew group becomes visible
  8. This step shows how to remove the top cover Remove the powder tray and all coffee beans. The cover is fastened with four Torx T10 screws. Those are easily found under the covers as well as the small cover on the left back side.
    • This step shows how to remove the top cover
    • Remove the powder tray and all coffee beans.
    • The cover is fastened with four Torx T10 screws. Those are easily found under the covers as well as the small cover on the left back side.
    • Also, remove the two Phillips screws on the bean container and remove the bean container.
    • Lift the cover upwards.
    • If it is stuck, carefully pry with a plastic opening tool.
    • The lid of the bean container is held in place by a small strong magnet that loosely rests. It is either in the green marked depression, or it remains hanging on the bean container. Make sure it is not lost!
  9. Pull the left side panel backwards to take it off. Pull the left side panel backwards to take it off.
    • Pull the left side panel backwards to take it off.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
91%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
95,834 Reputation
105 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 56
All Time: 513
