Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
The brewgroup produces the coffee. The inner seals are heavy used and must be replaced from time to time.
Parts
No parts specified.
  1. Always remove the power cord from the wall outlet. Lift out the coffee tray
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
  2. Remove the cup heat plate. It can be opened like a book.
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. The top cover is now free. Lift ´er up and set ´er aside.
    • The top cover is now free. Lift ´er up and set ´er aside.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the knob for the steam valve by simply pulling it off. The front cover is secured with a Torx T15 screw. Remove it.
    • Remove the knob for the steam valve by simply pulling it off.
    • The front cover is secured with a Torx T15 screw. Remove it.
  6. Now the front cover can be opened like a door for a few inches. The hinge is on the left.
    • Now the front cover can be opened like a door for a few inches. The hinge is on the left.
  7. Various hoses hinder the further opening of the front cover. You need to remove the steam valve keypad from the cover.
    • Various hoses hinder the further opening of the front cover. You need to remove the steam valve keypad from the cover.
    • Use a spudger to lift the two notches at the top of the front cover a bit to release the keypad at the top.
    • Lift the keypad upwards and pull it to the back. The steam pipe will slide out from its connection.
    • All hoses can remain connected.
  8. Remove the silicone hose leading from the steam valve to the coffee spout. If it is secured with a cable tie which must be removed first.
    • Remove the silicone hose leading from the steam valve to the coffee spout. If it is secured with a cable tie which must be removed first.
    • The front cover is now free and can be opened.
  9. The hot water from the boiler flows using a pressure hose with elbow connector towards the drainage valve. The connector is secured with a clamp. Pull the clamp from the connector.
    • The hot water from the boiler flows using a pressure hose with elbow connector towards the drainage valve. The connector is secured with a clamp.
    • Pull the clamp from the connector.
    • Lift the elbow connector up from the drainage valve. You may need some force.
    • The connector is sealed with an O-ring. The ring may remain either on the connector itself or in the drainage valve. Replace it when reassembling.
  10. Remove the three Torx T15 screws, one on the lower left side, two on the lower right side. Now the brew group can be removed. It is fixed on the upper edge with latches. First pull on the lower edge, then lower the brew group. You can remove it, wenn the latches on the upper edge come free.
    • Remove the three Torx T15 screws, one on the lower left side, two on the lower right side.
    • Now the brew group can be removed. It is fixed on the upper edge with latches. First pull on the lower edge, then lower the brew group. You can remove it, wenn the latches on the upper edge come free.
    • For dissassembling and maintanace of the brew group use this guide.
    • For dissassembling and maintanace of the drainage valve use this guide.
Special thanks to these translators:
83%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
94,185 Reputation
99 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 39
All Time: 501
