Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Patch your jeans with a reverse applique. This technique is great for holes that have a large chunk of cloth missing. You can cut any shape and use any color fabric for the patch, so long as it is heavy-weight fabric.
For replacement parts or further assistance, contact Patagonia Customer Service.
  1. Examine the damage. Clip any long threads, and remove any debris from the hole. Measure the damaged area. In our case it looks to be 2" by 2".
    • Examine the damage. Clip any long threads, and remove any debris from the hole.
    • Measure the damaged area.
    • In our case it looks to be 2" by 2".
  2. Draw any the shape you'd like your patch to be on a piece of paper. Be sure your design is at least 1/8" larger than the damaged area. Cut out your design.
    • Draw any the shape you'd like your patch to be on a piece of paper. Be sure your design is at least 1/8" larger than the damaged area.
    • Cut out your design.
  3. Lay the cutout of your design over the hole in the jeans to make sure that it is the correct size and looks how you want it to. Lay the cutout of your design over the hole in the jeans to make sure that it is the correct size and looks how you want it to.
    • Lay the cutout of your design over the hole in the jeans to make sure that it is the correct size and looks how you want it to.
  4. Using a pencil, pen, or tailor's chalk, trace the design onto the jeans. Using a pencil, pen, or tailor's chalk, trace the design onto the jeans. Using a pencil, pen, or tailor's chalk, trace the design onto the jeans.
    • Using a pencil, pen, or tailor's chalk, trace the design onto the jeans.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Cut the design out of your jeans. Be sure to only cut one layer of denim, or you will cut through the back of your jeans and need two patches! Be sure to only cut one layer of denim, or you will cut through the back of your jeans and need two patches!
    • Cut the design out of your jeans.
    • Be sure to only cut one layer of denim, or you will cut through the back of your jeans and need two patches!
  7. Take the scrap of fabric you will use for a patch and insert it into the hole. Take the scrap of fabric you will use for a patch and insert it into the hole. Take the scrap of fabric you will use for a patch and insert it into the hole.
    • Take the scrap of fabric you will use for a patch and insert it into the hole.
  8. Slide the pant leg with the patch over the arm of the sewing machine. You may need to remove the sewing machine table for the pant to fit over the sewing machine.
    • Slide the pant leg with the patch over the arm of the sewing machine.
    • You may need to remove the sewing machine table for the pant to fit over the sewing machine.
    • If you are still having trouble getting the pant around the arm of the sewing machine, you can rip the side seam of the pant leg to allow room to sew.
    • Be sure that the pant leg is around the arm, and that you are not accidentally sewing the two layers of the pant leg together.
  9. Adjust the sewing machine for a zig-zag stitch. Set the stitch length to just under 1/2.
    • Adjust the sewing machine for a zig-zag stitch.
    • Set the stitch length to just under 1/2.
  10. Align the edge of the patch with the center of the pressor foot. Be sure that the patch is laying flat.
    • Align the edge of the patch with the center of the pressor foot.
    • Be sure that the patch is laying flat.
    • Lower the pressor foot.
    • Begin sewing the zig-zag stitch, following the edge of the hole so that the zig-zag stitch covers the area where the two fabrics meet.
  11. Sew all the way around the patch. Overlap the stitching at the end with the first two or three stitches. Overlap the stitching at the end with the first two or three stitches.
    • Sew all the way around the patch.
    • Overlap the stitching at the end with the first two or three stitches.
  12. Lift the pressor foot and needle. Slide the pant leg off of the arm of the sewing machine.
    • Lift the pressor foot and needle.
    • Slide the pant leg off of the arm of the sewing machine.
    • Clip any threads, and admire your work.
Finish Line
4 other people completed this guide.
Brittany McCrigler
84,179 Reputation
132 Guides authored
One Comment
To keep the pattern from entirely fraying or catching on things, it may also help to flip the pants right-side-out and sew again around the pattern edge with the zigzag or a flat stitch.
Alisa - Reply
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 109
All Time: 5,727
