Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Step by step tutorial for blade replacement.
Applicable for following machines :
STERWINS 1-33 1200W 33cm
STERWINS 360ep 3w-1
STERWINS 2-36 1400W 36cm
STERWINS 2-40 1700W 40cm
Tools
Parts
    • Turn the mower off and turn it over to access the blade.
    • Position the correct size pipe wrench or socket wrench on the blade nut.
    • Lock the blade in the opposite direction of unscrewing with a piece of wood and hold it firmly.
    • Unscrew the blade nut while firmly holding the blade shim.
  1. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
    • Remove the blade fixing bolt and its washer. Place them close, they will be reused to fix the new blade.
    • Remove the worn blade from its holder.
    • Place the new blade on the support, matching the shape of the support pins with the cutouts on the blade.
    • Insert the fixing bolt with its washer and start to screw it by hand into the blade holder.
    • Using the shim and the pipe or socket wrench used for disassembly, tighten the blade fixing bolt.
    • Check the blade tightness using a torque wrench. The tightening must be 40 Nm.
To reassemble your machine, follow instructions in reverse order
Special thanks to these translators:
84%
Clément Delporte is helping us fix the world! Want to contribute?
Start translating ›
Clément Delporte
201 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 83
All Time: 83
