Fix Your Stuff
Right to Repair
Store
Introduction
Here's a step-by-step tutorial to dismount DS1019+ NAS until you reach the motherboard.
'Note: the interest of this tutorial is however limited.'
Indeed, most of the components that a user can be brought to add or change are now accessible directly, without disassembly (storage disks, memory expansion, SSD cache).
This is a step forward since, for example, a DS415 + / DS916 + must be completely removed to change a single RAM array.
Only the memory stack on the motherboard and fans remain inaccessible directly and require the disassembly of the NAS described in this tutorial to be changed (whether they are HS or replace them not the best).
The dismantling time is estimated at one hour (a single experiment on the timer). That said, it is certainly achievable in 20/30 minutes.
The photographs were taken with an iPhone Xr, un trépied SIRUI T-025SK, using a portable LED studio.
nota : le résultat est acceptable, mais en régression niveau qualité (manque de temps pour traitement des photos et qualité focus / netteté).
Tools
Parts
No parts specified.
  1. Here are the different interesting faces of the case: front (bay disks), rear (connectors and fans), below (2 hatches SSD). This NAS DS1019+ is equipped with 8 GB of memory, an INTEL Celeron J3455 64-bit Quad processor, five bays for SATA drives. FRONT : disk cage lock / REAR : Kensington security incision (K-lock)
    • Here are the different interesting faces of the case: front (bay disks), rear (connectors and fans), below (2 hatches SSD).
    • This NAS DS1019+ is equipped with 8 GB of memory, an INTEL Celeron J3455 64-bit Quad processor, five bays for SATA drives.
    • FRONT : disk cage lock / REAR : Kensington security incision (K-lock)
    • 2 USB 3 ports (1 in front and 1 behind)
    • 2 x RJ45 Gb ports.
    • FRONT : 1 port for power supply
    • BELOW : 2 M.2 NVMe 2280 ports (disk cache)
    • REAR : 1 eSATA port
  2. Before teardown, unlock the disk media with the key.
    • Before teardown, unlock the disk media with the key.
  3. Since the media are unlocked, remove each disk media. Since the media are unlocked, remove each disk media.
    • Since the media are unlocked, remove each disk media.
  4. This is a significant innovation, the memory is now directly accessible and without disassembly of the housing, for the original bar as for the extension port. backplane with 5 SATA connectors 2 memory slots
    • This is a significant innovation, the memory is now directly accessible and without disassembly of the housing, for the original bar as for the extension port.
    • backplane with 5 SATA connectors
    • 2 memory slots
  5. Remove the 2 screws on the back of the case at the top and bottom (not the one above the USB port)
    • Remove the 2 screws on the back of the case at the top and bottom (not the one above the USB port)
  6. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  7. Slide the cover forward, then slide it out (here, to the left). Slide the cover forward, then slide it out (here, to the left). Slide the cover forward, then slide it out (here, to the left).
    • Slide the cover forward, then slide it out (here, to the left).
  8. in red: SSD M.2 expansion card 2280 in yellow: USB 3 port in orange: internal connectors of the 2 fans
    • in red: SSD M.2 expansion card 2280
    • in yellow: USB 3 port
    • in orange: internal connectors of the 2 fans
    • in green: 2 slots of RAM
    • in blue: SATA III backplane (5 hard drive bays)
    • in pink: fixing the fans on the chassis
    • 3-PIN connectors of the fans
  9. Insérez ici votre traduction Insérez ici votre traduction
    • Insérez ici votre traduction
    • Remove the 2 screws from the holding plate of the USB connector 3 and on the rear side.
    • Then remove the USB3 metal plate.
    • Removal of the SSD M2 board is not necessary for motherboard disassembly.
    • Do not remove the USB connector 3 on the motherboard, it is glued. It does not interfere with disassembly!
  10. Remove the screws from the two shims to secure the disc cage and the two fans. These plastic spacers are keyed These plastic spacers are keyed
    • Remove the screws from the two shims to secure the disc cage and the two fans.
    • These plastic spacers are keyed
  11. 4 Phillips screws must be removed from two side. Remove the fans's 3-PIN power cable Remove the fans's 3-PIN power cable
    • 4 Phillips screws must be removed from two side.
    • Remove the fans's 3-PIN power cable
  12. Here, the motherboard is still secure to the disk cage. Remove the motherboard from the case paying attention to the USB 3 connector on the front and the power button. To do this, move the front panel a little and lift the motherboard upwards (outside).
    • Here, the motherboard is still secure to the disk cage.
    • Remove the motherboard from the case paying attention to the USB 3 connector on the front and the power button. To do this, move the front panel a little and lift the motherboard upwards (outside).
    • Take care.
  13. Once the motherboard is out, unscrew the 4 screws of the metal protective cover (metal plate). Once the motherboard is out, unscrew the 4 screws of the metal protective cover (metal plate). Once the motherboard is out, unscrew the 4 screws of the metal protective cover (metal plate).
    • Once the motherboard is out, unscrew the 4 screws of the metal protective cover (metal plate).
  14. Motherboard processor side
    • Motherboard processor side
    • INTEL Celeron J3455 / 64-bit / Quad core 1.5 burst up to 2.3 GHz
    • Memory battery
    • Internal beep
    • USB 3 port
    • Power button
    • Flash memory
  15. Memory side of the motherboard (pre-equipped with 8 GB of RAM)
    • Memory side of the motherboard (pre-equipped with 8 GB of RAM)
    • NVMe M.2 SSD expansion card connector
    • Connector (PCIe ??) for SATA disk expansion card
    • Fan connector (x2)
    • Power connector
    • RJ45 LAN Connector x2
    • ESATA connector
    • 2 x 4GB DDR3L 1866 RAM Memory Stick
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
96%
Sébastien is helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Sébastien
1,477 Reputation
5 Guides authored
AEM (ANIMA EX MACHINA) Member of AEM (ANIMA EX MACHINA)
Business
1 Member
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 41
All Time: 41
