Fix Your Stuff
Right to Repair
Store
Introduction
Put some feeling back in your gameplay by replacing the vibrator motors in your Xbox 360 wireless controller.
  1. Depress the battery release button on the top of the controller. Remove the battery holder from the controller.
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Use a pair of tweezers to peel the barcode sticker from the battery compartment.
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Remove the seven 9.3 mm  T8 Security Torx screws securing the rear case to the front case.
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Insert a spudger between the front and rear cases, near the headphone jack. Rotate the spudger toward the front of the controller to pry the two cases apart.
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Grasp the controller by the battery compartment and the headphone jack. Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board. Lift the vibration motor out of the front case.
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Remove the vibration motor from the other side of the controller using the same method previously described. The right motor has significantly more counterweight than the left motor.
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The right motor has significantly more counterweight than the left motor.
17 other people completed this guide.
Brett Hartt
117,761 Reputation
143 Guides authored
iFixit Member of iFixit
Community
129 Members
12,526 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 86
All Time: 32,000
