Fix Your Stuff
Right to Repair
Store
Introduction
Your iPod's motherboard controls just about everything on the iPod.
  1. Before opening your iPod, ensure that the hold switch is in the locked position.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
  2. Lift the top bezel off of the iPod.
    • Lift the top bezel off of the iPod.
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
  3. A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
  4. Lift the metal retaining bracket out of the iPod.
    • Lift the metal retaining bracket out of the iPod.
  5. Be careful, this connector is fragile.
    • Be careful, this connector is fragile.
    • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
  6. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  7. Remove the two #00 Phillips screws securing the headphone jack to the casing.
    • Remove the two #00 Phillips screws securing the headphone jack to the casing.
  8. Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
  9. After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
    • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
  10. Lift the battery off of the logic board and lay it to the side of the iPod.
    • Lift the battery off of the logic board and lay it to the side of the iPod.
  11. Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
    • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
  12. Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
    • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
  13. Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
    • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
  14. Turn the iPod over.
    • Turn the iPod over.
    • Carefully lift the display up and slide it out of its connector.
  15. Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
    • Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
  16. Carefully disconnect the battery from the logic board. Make sure to pull only on the connector and not on the battery wires.
    • Carefully disconnect the battery from the logic board. Make sure to pull only on the connector and not on the battery wires.
  17. Use a spudger or the tip of your finger to carefully disconect the orange hard drive ribbon from the logic board.
    • Use a spudger or the tip of your finger to carefully disconect the orange hard drive ribbon from the logic board.
    • Lift the hard drive out of the iPod.
  18. Logic board remains.
    • Logic board remains.
18 other people completed this guide.
iRobot
1 Reputation
648 Guides authored
One Comment
Can You give me a step by step process for reassembling an iPod mini after replacing the logic board. I cannot follow the steps in reverse to reassemble it. Also, is there a youtube video showing the reassambly?
ahmartensson49 - Reply
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 81
All Time: 21,835
