Fix Your Stuff
Right to Repair
Store
1 TB 7200 RPM 3.5" Hard Drive
  • 1 TB 7200 RPM 3.5" Hard Drive
  • 1 TB 7200 RPM 3.5" Hard Drive / Seagate
$59.99
$59.99
Product Details
Description
Description
Replace or upgrade the hard drive in your compatible iMac with this part.
Compatibility
Compatibility
  • iMac G5 17" EMC 2055
  • iMac G5 20"
  • All 21.5" and 27" pre 2011 Intel iMacs
  • All G5 Power Macs
Specifications
Specifications
Model #:
DT01ACA100
Cache:
32MB
Drive Capacity:
1 TB Unformatted
Speed:
7200 RPM
Dimensions:
3.5" (88.9mm) wide x 1" (25.4mm) tall
Interface:
SATA 6.0 Gb/s
Compatibility
iMac G5 17" Model A1058
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
A1311 Late 2009 iMac10,1 3.06 GHz
A1311 Late 2009 iMac10,1 3.33 GHz
iMac Intel 21.5" EMC 2389
A1311 Mid 2010 iMac11,2 3.06 GHz
A1311 Mid 2010 iMac11,2 3.2 GHz
A1311 Mid 2010 iMac11,2 3.6 GHz
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 & 2374
EMC 2309 Late 2009 iMac10,1 3.06 GHz
EMC 2309 Late 2009 iMac10,1 3.33 GHz
EMC 2374 Late 2009 iMac11,1 2.66 GHz
EMC 2374 Late 2009 iMac11,1 2.8 GHz
iMac Intel 27" EMC 2390
A1312 Mid 2010 iMac11,3 2.8 GHz
A1312 Mid 2010 iMac11,3 2.93 GHz
A1312 Mid 2010 iMac11,3 3.2 GHz
A1312 Mid 2010 iMac11,3 3.6 GHz
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
Show 13 more devices
Repair Stories
User avatar
Jane Pearson's Story Photo #1123352
Jane Pearson's Story Photo #1123351
Jane Pearson's Story Photo #1123349
My Problem
Computer wouldn't boot even after trying multiple resets and safe boots. Attempted to erase hard drive but could not load OS. Decided to replace drive.
My Fix
The video and step by step directions made replacing the drive a breeze. My 16 year old son (who has autism) and I followed the directions and fixed . . .
User avatar
My Problem
Other part was not working anymore, so I went with you guys and problem salved :)
My Fix
Was easy and very exciting to do, your part fit in perfectly
My Advice
None because your products are amazing and will be recommending to everyone I know
User avatar
My Problem
iMac internal hard drive failed and needed to replace to use computer.
My Fix
Had my 9 year old son help read instructions while i was doing the work, as my hands were busy. I sprayed out the computer from dust accumulated over the last 8 years, which took me longer than the 1 hour it could have.
My Advice
When bootin . . .
User avatar
My Problem
Hard drive Failed
My Fix
Perfect as instructed.
My Advice
You don’t need to buy any suction cups. Do you have packing tape? Lay it across the screen at the top through two loops of tape in the corners. Pull. The other tool recommended, the stick, I don’t know what it’s for, but I didn’t need it. Just torx . . .
User avatar
My Problem
Hard drive failed and it was quoted at $500 to install a new one.
My Fix
Repair went great! Step by step instructions with photos made it super easy.
My Advice
Don't be intimidated! It's actually quite easy!
User avatar
My Problem
I did not fix any problem, I'd rather upgraded my iMac 21,5 late 2009 with a new HD
My Fix
Everything went just fine
My Advice
The repair guides are absolutely helpful. Awesome
User avatar
My Problem
Old drive died!
My Fix
Smooth replacement, a bit dusty inside.
My Advice
Keep an eye out for the mic wires when reinstalling the display
User avatar
My Problem
I had to replace a dead hard drive
My Fix
It wasn't bad at all. The hard drive that was sent was not the same in the iMac. This means I could not use the thermal sensor. However, I found a website that allowed me to use it. Besides having big fingers, it wasn't that bad.
My Advice
Have another person helping you. When . . .
User avatar
My Problem
Hard Drive failed on computer. Since it was seven years old, bought new iMac and decided to repair this old.
My Fix
The repair essentially went as advertised except for item listed below.
My Advice
Had to do in stages as instructions stated need same manufacturer for hard drive so that temperature monitor connection . . .
User avatar
My Problem
The original had become unusable. Too many sectors gone bad.
My Fix
The iFixit PDF was almost dead on accurate.
My Advice
In my particular case, the thermal sensor cable warnings didn't apply. The connections were built as such that there is only one way to plug it in if it was to be plugged in at all. Now this might . . .
Show more
