Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Disassembly to get to the sensor. Some images are courtesy of lifepixels.com
This teardown is not a repair guide. To repair your Panasonic Camera, use our service manual.
  1. I have dust particles underneath the sensor glass, so sensor swabs didn't  help me. I will try to get inside and under the glass. Additionally the EVF is overbright after a drop and maybe can be rearranged in the process. You can spot the dust best if you set the camera to the "A" mode at f/22 and take a picture of the sky You can spot the dust best if you set the camera to the "A" mode at f/22 and take a picture of the sky
    • I have dust particles underneath the sensor glass, so sensor swabs didn't help me. I will try to get inside and under the glass. Additionally the EVF is overbright after a drop and maybe can be rearranged in the process.
    • You can spot the dust best if you set the camera to the "A" mode at f/22 and take a picture of the sky
  2. Start with these two screws. Remember screw sizes and position, there are many different lengths used!
    • Start with these two screws. Remember screw sizes and position, there are many different lengths used!
  3. remove the flash spring as shown and the four screws remove the flash spring as shown and the four screws remove the flash spring as shown and the four screws
    • remove the flash spring as shown and the four screws
  4. Remove this screw
    • Remove this screw
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Insert wisdom here.
    • Insert wisdom here.
  7. remove the backplate and remove the ribbon cables remove the backplate and remove the ribbon cables
    • remove the backplate and remove the ribbon cables
  8. remove the 3 screws
    • remove the 3 screws
  9. to remove the sensor more easily you can remove the top bar before to remove the sensor more easily you can remove the top bar before to remove the sensor more easily you can remove the top bar before
    • to remove the sensor more easily you can remove the top bar before
  10. Flash E.Capacitor removal
    • Flash E.Capacitor removal
  11. Remove the 3 screws to get the sensor cover glass off. Be Careful not to let them fall inside the housing. There are extremely strong magnets! Remove the 3 screws to get the sensor cover glass off. Be Careful not to let them fall inside the housing. There are extremely strong magnets!
    • Remove the 3 screws to get the sensor cover glass off. Be Careful not to let them fall inside the housing. There are extremely strong magnets!
Andi
191 Reputation
1 Guide authored
3 Comments
Hello,
and what about Flange back adjustment? Did you solve it somehow?
Štěpán Karásek - Reply
Hi, what exactly do you mean? I managed to wipe the sensor clean, but correct reassembly is difficult. I might have missaligned the magnets holding the sensor and now the camera sometimes seems to focus very slow.
Andi -
How do you remove the top case unit or top bar?
Nigel - Reply
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 85
All Time: 2,021
